Tranny Issue!
DirtRider045
Minnesota
After bashing the truck through about half a tank i shifted into reverse, then shifted back into forward however the truck would not go. It creeped forward with throttle wide open and then would not move at all in either direction! spur gear and clutch bell are fine and it was completly shifted into gear. Could the problem be the clutch inside the tranny?:\
Was there any other sounds coming from the tranny ? You could have broken the pin that holds the primary gear to the main shaft . I've broken a few myself.
I guess I should have asked what version T-maxx do you have ? I have the original version tranny in mine and I dont know if the internals in all versions are the same .
