You want to be running high end stuff for high performance motors. Its not a lawnmower engine.
Use new containers with no grass clippings in. Use new funnels with fresh filters each time.
Keep the crap out of the tank to start with.
If you are unsure of mix, I'd go with a lower fuel/oil ratio. It might smoke, not run at peak but it will be well lubed and not burn a hole in your piston or rings.
Invest a little into this thing just from the start and you will get WAY better results.
Oil filter, air filter, replace it. Research, verify plug is correct, then buy a new one. Or 3.
I would pull the fuel tank and clean it out well and replace fuel lines too.
This is based on nitro and 1:1 experience though, I don't own THIS buggy.
