tomcoleman
RCTalk Qualifier
Damn...that remote is wicked!!!
i suggest you put FOC in. remove all that optidrive stuff. change it to pull start with a glow igniter. much easier and less crap you have to carry around. regardless of the belt clip...
2 steering servos will drain your battery more too. i removed mine and it works just as good as 2.... if you don't believe me all you have to do is take the link off one and do a lap to see. apart from that.
are you going to put a wheelie bar on? i know mine doesn't wanna stop doing wheelies all through first and that wing might not last too long if its rubbing on the ground![]()
any electrics fail after snow run? the first time i ran my revo in wet/damp grass and puddles yeh. throttle servo gone and major clean lol.
take off the front bar. and take off the skid plates on the underside. there are 2 metal rods you need to pull out on the top and 4 on the bottom half (bottom ones are not full rode hence 4 in total)
what springs and preload measurement have you got ur shocks set at? and do those new red arms make it lower or is it just the suspension setup?
