Cupooterluvr
My TMaxx, which was in great tune before today, will not idle down. It might be because I replaced the stock traxxas glow plug with a McCoy 59 plug, which was recommended by the man at the LHS. I would like to know if this is the correct plug, or if I should go back and get the Traxxas plugs.
I tried decreasing the idle set screw, and richening the LSN, along with fully applying the brakes when setting the idle. It just stays where it is. I then tried letting it cool and restarting it, at which point the idle was still very high, but it would cycle from low to high.
The idle isn't high enough to fully engage the clutch, but it is high enough to make the clutch shoes drag on the bell.
Side note: I flooded the engine when starting it today, but I think it was just because I primed it too long. Also, I use a separate glow ignitor (1.2 volt rechargeable nicad). The ambient tempurature was approximately 5 to 10 degrees F cooler today than when I ran it last.
Any help appreciated.
