Ok so I had my starter housing one way barring housing crack so I replaced it. So went to crank it and had the bearing backwards. So got that fixed. I use the ez start and you can hear it crank over. I did reset everything back to factory. However not changing any setting it will not start. The only way it will start and idle is if I give it a little extra gas and it runs fine then. So I would guess some odd carb setting but not sure why it is doing this now. Any thoughts?
