Well I discovered the hard way if you install a 66 tooth spur gear with the 20 tooth clutch bell you will not get close enough to the spur gear to get a good mesh on the gears. Even though it seemed to fit tight enough during installation it strip the spur gear in no time at all.
To fix the problem I installed a 25 tooth Clutch Bell on my TMaxx 2.5r engine this should also increase my speed a bit. When meshing the gears I have found that cutting a small strip of regular paper about 2 inches long and a 1/4 of inch wide then pressing the engine into the spur gear will provide just enough clearance so you do not have the gears too tight together.
I will be interested to see how much faster it will run around the track.
