tmaxx center shafts
mckinney03
lafayette oregon
Can anyone tell me what brand and part number they use to upgrade there center shafts on there tmax model number 4907.. broke 3 rears in one day..thanks for ur help
I haven't seen a set for the 4907 (doesn't mean there isn't, I just haven't found them) you could just fit an HPI 77mm Dog Bone and a couple of 5353R Traxxas Drive Cups in the rear. Many people run this way.
may be wrong but arent the 4907 the same as what goes in the revo? If so u must be real hard on them cause i have been through gallons with no trouble. Maybe ur slipper is all the way tite or something.
ya i am really hard on the tmaxx....never had a problem with the drive train untill i put the picco in......owell stock drive lines r cheap. i will just keep replacen them untill i can find metal ones......thanks everyone..
I have a set of revo shafts on my old .15 max front and rear.had to when i converted to a 3.3 motor
Use the HPI 77mm bone & dr cups for your rear center, it's the most bullet proof setup there is right now for the 4908/07.
MIP is top notch gear.
Ya I put the mip in myself. I was breaking the stock ones all the time. Now I've had no trouble at all.
problems fixed..my buddy ordered so mip but they were to short,so i cut them in half took some 3/16steel shaft drilled a hole threw it and made them longer...now if my welds dont break I'm fine lol
I did something similar w some shafts that were to short..... because they had globs of weld on them and were off balance i was going through bearings quick.
