Tmaxx 3.3 problem
skull791
Hey everyone. I'm very new to this. I recently got Tmax 2.5 with 3.3 engine in it. Got it tune by a local shop first time so I can understand how it works. My problem is that some times car will start creeping up or jumping forward. What is this cause by. I play with idle and still dose it. some times is very bad some times is just once in white. any suggestion are welcomes. The only mod I can see it a metal big wheele on transmission.
Tmaxx 3.3
Check your clutch,maybe your spring came off inside if this happens then the truck will try to roll forward when you try to start it up.
let me know if this helps.
Regards,3DKing
I did look and everything looks ok. any other sugestions ?
Mine had been doing the same thing...noticed it after running it in the sand. Remove the Clutch bell housing and verify your bearings on either side are good. Make sure there is no debris internal to the housing. I found that I had gotten sand in the clutch bell housing, and it tore up my bearings!! Double check your clutch shoes!!
