tmaxx 3.3 axles?
If the axles are not revo spec they should fit. The revo spec axles use a different size out put shaft from the diffs if I remember correct. 4909 and 4908 models are revo spec 4910 is a older style or should I say original style
3.3 wheel axles are revo spec and will not fit the 4910 axle carriers.
If you install the 3.3 axle carriers (you will need the longer toe links also) the 3.3 spec wheel axles will fit.
so i guess i would just be better off goin with the metal cvds? i was just lookin for the cheaper but tougher fix.
RC Builds
