TMAXX 2.5 steering problem
NitroRider
  1. Racing
I have my truck put back together now. So I took it out on saterday. And for reason I dont have any steering at all. I was told that the parts might be to tight in the front end. So I losen the scews up and it well turn fine by hand but not by remote. I changed the steering sevo saver around in every way it well go. And it didnt change anything. As far as I can tell that there is nothing more broken on the truck.
So I am stumped and dont know what to do. If someone has a picture of how
the servo is suposed to be on the truck that might be the problem. I am thinking I might have put the new servo in backwards.
I just dont know.
did you plugz it in right??
Check your connections. If you're using any Traxxas radio system, the steering is channel 2 on the receiver. If that doesn't work, check to see if your throttle/brake servo is working. If not, look at the batteries. If so, check the wiring to the servo for breaks. If that doesn't solve it, it could be a bad servo.
