tires
what? what about them? Take the time at least type in sentances to make it somewhat understandable if your not going to take the time to do the research yourself.
Also some more info might help. Like on what surfaces and such..
what tires have the most traction on road and on gravel- loose dirt?
There are 3 different answers for that question and there will be people that have different opinions about what others say.
An on road tire is designed for on road.
A loose dirt tire is designed for loose dirt.
A tire for loose gravel is designed for loose gravel
For on road is it a newly paved street, old asphalt, concrete? Is it dusty or prepped?
Dirt, is it deep, shallow, thick, thin, whats under the dirt?
Gravel, What size is the gravel how deep is it, whats under it?
When you ask what has the most traction, you will need to be extremely specific as to what the conditions are. There is not one answer to what tire has the best traction.
Are you looking for a good all around tire that you can run on any surface and get fairly good performance?
Dirt Hawg II, and Dirt Works are great all round tires, i got a pair of Gladiator II they are a great gravel, loose dirt tire but they will wear out a bit quicker them the Dirt HawgII and the Dirt Works on the street.
what tire is good for on road newly paved asphalt?
what tire is good for dirt that is very thin with solid rock underneath?
what tire is good for gravel tha is just like chipped rock?
And what is the beat all around tire
please give web site or maker
what is the best track tires
what is a good rim to put on my rusty right now i have the traxxas deep dish rims. i was wondering what other rims would be nice and cheap (beed lock?)
right now i am running the i mex super swamp dawgs and they run good should i stay with them or change over?
Their is NO one good tire. it all depends on the track and surface and what the track is made of. this are all racing tires and you have to figure what will work best on your track. also you have to worry about front tires. some tracks you can use some type of edge tire and on others you can use a rear tire up front.http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDX78&P=7 http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFHL6&P=7 http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDX79&P=7 http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHEN2&P=7
Alos you need to worry about what compound to use, M2, M3. What type of track are you running and what is it made out of. then we can help you narrow down a type of tire
i mostly run on pavement half the time and the other is on grass or loose dirt what is the best tire combination ?
Dirt Hawg II, Dirt Works, and the Moab are the best all around tires. for pavment, dirt and grass. Moabs are good but they are larger and they cost more so i would just stick to the Dirt Hawgs or Dirt Works tires
The dirt works are nice cause they have a close tread pattern so they will last the longest and work the best on-road then the Dirt Hawgs and the Dirt Hawgs tread it farther apart so they will get better grip off-road and will wear down a bit faster.
It is your choice their are pros and cons for each
the Moabs are a larger tire so you will have to get a bigger engine or change the gearing. so I would just stick to the Dirt Hawgs or Dirt Works
