I havnt been around much lately because i have actually been running these money pits. However on my truggy, my right rear tire wobbles like a bia. Its tightend all the down on the hex. Any suggestions?
they may have came unglued.. (if there glued) or bunched up.. try masaging them to get it to go back to the right place.. or yo uwill have to unglue them..
It could be a messed up wheel or the foam is uneven, also check to make sure you tires are glued all the way around, i had a rock get wedged between the tire and wheel and made the tire wobble
if htey are on bead locks then take em off and reset the wheel on the rim....if you haven't done it..take your body reamer and drill a pinhole on the inside of the rim so water can get out too.....like 1 to 2 mm hole is enough..
