Tips to keep tmaxx run good for a long time?
rolsy100
Minnesota
if anyone has any after run tips or tricks post em here! or anything to give my 3.3 a long life! thanks.
for a long life on the 3.3 run her a little rich get that performance tune then richen back up a tad the 3.3 has a tendency to snap the rod when its tuned for performance and your really pushing the motor. Main thing on motor USE AFTER RUN OIL EVERY TIME YOU PUT IT UP FOR THE DAY. and b4 adding ARO (after run oil) make sure all the fuel is burnt from the case even when it dies from running out of fuel there is still fuel in the case. Start it up until you dont get any fire then add ARO. Make sure you periodically check your clutch bell bearings and shoes.
Tune, good fuel, after run care, not running too lean & overheating it.
The quickest way to kill a TRX 3.3 is to run it lean & hot, it makes for a even weaker con rod.
