Normally the number stamped on the one way bearing portion is the manufacturer # of that specific OWB (which is pressed into the hex portion of the unit) and not the part # of the unit as a whole the manufacturer of the rc would use to identify it.
Your best bet it to measure the diameter of the starter shaft and the size of the hex the starter unit has and match it up with the bearing unit you need.
