Throttle Servo
Evan999
I own a T-max 3.3 and i'm fairly new at this but having a good time. my servo every now and again will pull to full throttle and stick there. Batteries are all good. Is this a servo that needs to be replaced or a transmitter problem
Any one with a solution.
If ALL your batteries are new and good and the same brand, I am going just assume your having a reciever/transmitter issue... I would swap out the servo first since its cheaper though... One of those pain in the rear things...
Do you have an AM or FM tx/rx? AM setups are prone to interference rather easily. Also to bench test the electronics switch the servo connections on the RX, if the problems stays with the throttle servo then the servo has a problem. If the problem moves to the steering (e.g. the wheels stick in the turned position) then the problem is with that channel on the tx/rx system.
