bifft it
Military Veteran
1. take the 2 screws out of the rollbar on throttle side, remove long throttle rod and turn it backwards and upside down
2. loosen the screw directly infront of the the 2 rollbar screws you removed and attach 1 end of the exhaust gasket spring (may have to pinch the loop closed a bit so screw withh grab it)
3. screw the 2 screws for the rollbar back in and attach the other end of the spring to the underside of the 90degree throttle boss and on what sticks out of the hole!
also: on a side note , i use the stock hpi return springs in the same manner, only i attach the big loop to the rollbar instead
