So I've got the Red Dot installed, but I'm having issues with the throttle linkage. The servo pulls the carb open to the max, but wants to pull further then gets caught and will even push the front linkage post backwards, allowing to throttle to stick open. I've placed the small pivot point in closer to the center on the servo horn. This change in angle helped somewhat. Being that I'm using the stock radio gear, I have no control over the end points. I've added a "throttle return spring" similar to the setup on the 3.3's. It works somewhat but on occasion, it'll stick.
You guys have any suggestions?
