Three Speed For Savage
ToFast2Drive
anyone have the Three Speed if so can you see any diff from it like more Speed at low and high end??
yep more torque on take off and much more top speed. especially if your running a 18/47 gear combo you wont be able to control it in 3rd unless your in a wide open area.
So, in your opinion, worth it or not? (if you have the money to buy a new engine)
i dont got one yet but its suposed to. Thats Why I'm getting it...I Will Tell You How It Is when I Get It
mine doesn't shift to 2nd OR 3rd which way do i turn the set screws to get them to adjust they are at factory settings i believe so what should i do PEOPLE WHO HAVE THE 3 SPEED IF YOU HAD TO ADJUST IT PLEASE TELL ME HOW MANY TURNS IN AND OUT PLEASEEEE
Mines doing the same thing ! OK do this adjust 1st/2nd gear by loosening the screw untill it starts to shift then do the same for 2nd/3rd . There is no set amount of turns because there are so many different engines with different power bands By the way loosening the screw will make it shift sooner and tightening will make it shift later
