ERSO_BANKS_NYC_2_FLORIDA
Gone - bye bye.
if you put that threadlock stuff on a screw........how do u remove the screw if needed?
Originally posted by pseudorhombicubictahedron
no its just a little harder to turn...make sure you have a quality screw driver though...
Originally posted by ImBroken
...A real easy way to remove a stripped out screw, is to take a dremel (with cutting wheel) and make a notch clean across the top, for a flat head screwdriver. You need to go as deep as you can without hitting the part its screwed into. ...
