Temp Q's
Tarant
Medford
Ok today I was able to bash for a good hour, well I recently moved the fuel tank to the front where the RX goes and I put the RX above the steering servo. works great I will try to get pics.
Well I was doing high speed runs and i took the temp of the brakes and it read 128 deg, is this normel, I put springs on the brake pad screws to keep them from rubbing the disk.
And lastly is the manifold temp acurate to the engine temp. My engine temp was 180 deg but my manifold temp was 230 deg. What gives :shrug:
Thanks
The manifold should be hot, because that is where the burning fuel is coming out! Yes, the brakes yet hot if you are using them.
I know the manifold will be hot but is it the same temp as the engine
cause I got two different temps
