Team Losi 8ight-T
I've found that while the clutch works very well in the buggy, it doesn't work too well in the truggy. It just wears to damn fast.
I use the Fioroni clutch in mine. This can handle gallons of abuse in a truggy.
These three things should get you everything you need to use this clutch in the 8ight-t. You may also have to use a shorter collet then what some with the Fioroni.
http://www.amainhobbies.com/product_info.php/products_id/4655
http://www.amainhobbies.com/product_info.php/products_id/4656
http://www.amainhobbies.com/product_info.php/products_id/2940
It's a little pricey but it is a great clutch.
Won't open for some reason but if it's the Maxlife shoes then those are the best shoes by far I have ever used. I have a set with 4-5 gallons on them and very minimal wear. You will not get that out of most any other aluminum shoe
Sweet, thanks guys. I will check it out right now.:bandit:
THe ones I found on a-main were Dynamite Max-life shoes, I will try those. Thanks guys!
