TC3 Steering???
BI_SRT-4
Kissimmee FL.
I have Ele TC3 and i just wanted to know why it makes nice tight cirlce's when i turn left but large wide circle's when i turn right.
Is that straight steering or a suspension problem?
Is your steering servo end points set so that you have equal throw in both directions?
You might want to center your steering servo. Then you can make the tiny adjustments using your transmitter. If your servo is uncentered and you try to fix it with the transmitter, it will cause the servo to go far in one direction but short in the other.
I restet the steering servo and adjusted the tie-rod's and its alot better then before. Thanks for the info.
