did carb function b4 servo swap?. if yes .then check servo. check horn .is it the correct teeth count. is servo working without arm or carb connecting rod? go down the line can you move carb manually?
Do shocks need to be service every two runs? Because mine seem to leak out the fluid after two days of running my tc3. I had changed the shock body to threaded ones
