hulkmaxx
Wanna know my secrect. I'm always ANGRY!
- Grantsville West Virgina
Okay guys got a diff truck in for repair. My Brother bought a older 2.5 Tmaxx off egay. After installing the engine, the trans will not pull. Spur just spins like crazy never incages the trans. I have tore it down inspected everything. And everything checks OK. The one way bearing is working correctly, all gears good. The set screw that holds the spring and bearing is tight, The set screw for the shift point adjustment is there. The set screw in the bottom gear is tight. I have cleaned and cleaned trans did not help. What else could I look for. And I am not sure how to explain this the, piece that holds the set screws for the shift point adjustment easily removable, I am not sure if you shoukld be able to pull that right off or if it should be locked onto the shaft.
