t-maxx termoil
billyca412751
Canada
my friend bought a used t-maxx 2.5 that worked fine up until the carb was wrongfully adjusted way out of wack! Can someone tell me the factory settings and what should be done to make it run properly once again? Right now its hard to start, wont idle smoothly(its up and down) and it doesn't wanna stay going. It does reach 220 degrees sometimes if he is lucky but it just dont want to run any good.Any suggestions?
:surrender:surrender
First off, check to make sure you don't have any air leaks or blockages (just to make sure...). Then, reset the HSN to 4 turns from closed, the LSN flush with the housing, and the idle gap at 1mm.
there is a tuning guide on the traxxas website. its on the front page under quicklinks and then when you find quickslink there is a link called factory engine settings click on factory engine settings and the tuning guide is on the bottom of the page.:yes:
