hey,yea it's a pain in the butt just did it. basicially you have to pull the front end apart.Then once you do that you can loosen up your disc brake pads so you can slide the disc back far enough to get the the new cv to slide on the tranny shaft and be able to put the set screw in.Hope that helps alittle bit.
