T-maxx 3.3 wont idle
T-maxxlover14
RCTalk Racer
Colorado
Ok so i just broke in my t-maxx 3.3 model 4908 and it wont stay idleing i have to give it some gas to keep it runing once i stop the truck for about 3 sec it will shut off can any one help thanks
You are in a cold area, and breaking in is all about heat cycling.
Aside from that, you need to tune the engine since the LSN is still set too rich.
ok so what happens is that when u pull the triger fast right of the bat it boges a bit then goes and it wont idle if it sits for more then 3 sec so all i want is it to idle then get rit of bog at low end so how do i do that in simple terms
Lean your low speed needle an 1/12 of a turn. No more than an 1/8. If it still doesn't want to idle, turn the idle screw up until it does. READ YOUR MANUAL. If you understand the manual and watched the dvd that came with your truck, the first response to your question would have been very easy to understand.
ok thanks alot i will do that tomorrow then post how it worked i think it will run fine now thanks man
