exilestudios
- Racing
Hello,
A couple weeks ago I had finally got my T-Maxx back together and ready to run. My dumb ass didn't think to lube it all up after having it sit for a while. Well I ran it for about 10 minutes and then it suddenly cut off. My EZ-Start was smoking, which highly concerned me. I assumed the EZ-Start was shot and I needed to replace it, as it wouldn't kick the motor over and had the smoke rolling out of it. I got to checking it out and found that it seemed to be seized up.
After tearing everything down I noticed the piston would move when I had the head off, but would appear to be seized again when I had it on (couldn't turn it over by hand). So I ended up having to tear off my EZ-Start and discovered the piston rod was split down the center and detached from the piston. Well after another week passed I had finally got around to getting a new piston rod. I ended up replacing it with aircraft alloy piston rod.
After putting it all back together (and making sure it was all good and lubed up this time
) my EZ-Start seemed to be turning the motor over, but there's another issue with this which worries me. When running the EZ-Start for about 2 mins I notice sparking inside the EZ-Start motor, but initially when I use the EZ-Start it doesn't do this. I'm wondering if this is normal and I just never noticed it or if something is seriously wrong with it. It concerns me a lot because if that sparking causes a little spilled fuel to ignite it would really be screwed, as the EZ-Start essentially lays on the fuel tank. I am thinking about replacing this with my next pay. Anyways, the main topic of this thread is that I am having trouble getting it to fire up. At first I figured well maybe I just need to retune my carb, so I set it all back to default settings. It still would not fire up, but it acts about half like it wants to every so often. I got to thinking and thought well maybe my fuel line is pinched some where or it's just not getting the fuel some how. After looking all of that over it didn't seem to be the problem. There was fuel coming up to the end that slides on the carb. I'm leaning towards thinking it's something to do with the EZ-Start. However, I wanted to get another individual's opinion about it before I go fork out around $20 for a new EZ-Start.
Thanks for taking the time to read this if you made it through all of that!
Edit - Hmm...Does the way the piston rod faces make any difference in the firing? Not like top or bottom as there's only one way it'll fit that way, but like the two sides? I wouldn't think it would...
