t maxx 3.3 popping plugs
By "popping" I assume you mean fouling?
What engine do you have?
RE RE RE check the factory settings, you may be using the settings for a differant motor.
If you are confused with the lsn flush; go on traxxas website and they have pictures there for you to reference.
ok people i love the help but i have been runing nitros for over ten years i know what hsn is and lsn and it doing this at stock or factory carb settings and i can't seem to find the cause of it the plugs are coming out looking like they were never even used
I / we are still running on the ASUMPTION that your complaint is fouled plugs...... maybee you should articulate a litle bit about that.
We now know its a 3.3 and you have the carb set at or close to factory specs.
WHATS IT DOING WRONG?
And what type of plugs are you using.
traxxas super-duty (long-medium) it seem to run fine for a few sec and then dies killed five plugs so fare on this one tank of nitro so that brings me to this could my nitro have gone bad over time this is the last tank or so out of a gallon i bought in may trx 33%
and the plugs all come out looking like they were never used
Well hopefully its the fuel.
If the plugs look NEW than they should still be working like new.
Your really not giving us much to go on.....
I can't answer the question if you dont ask it properly LOL
ok how about this got the truck to idle fine now with truck off of the ground i give it just a little gas and then just a little more and then dies truck will start right back up i went with new gas last night and no change I'm only able to make the truck move just alittle on it own power anymore then that the truck die i did notice that if i just let it sit there and idle that the idle would change rev up a little then slow down lower then before i live in arizona does any body know of a hobby shop that does the trx engine swap i think thats what I'm going to do i have already spent more on glow plugs this week then the swap would of costed me i did find fuel in the muffler but this is from factory settings i found this so went leaner but still no good wont stay runing i replaced the fuel line before this all happend but before the line got hear i used my jato line and it ran great got the new line and one tank latter it's doing this should i run a longer line then
i dot know if this will help but check your glow plug by putting it in your glow igniter if it doesn't glow bright orange it might be the glow igniter, or it might be the glow plug =p If it glows bright orange then i dont know.(this might not help lol only been in the hobby for under 1 year =p):D
