t-maxx 3.3 after run what do i do
T-maxxlover14
RCTalk Racer
Colorado
so after breaking it in the t-maxx 3.3 that is i sprayed a 1 sec burst of wd-40 in the top of moter then the same in carb i turned it over with ez start but did not turn the truck over and let eces wd-40 out is that ok or what do i do now to start it up again
That SHOULD be fine.
If it wont turn over..... your flooded ( with wd 40 ) take out the glow plug and crank it over to get the exxes oil out.
That should not be too much. I would not put in anymore than that though. Oh yeah, also always remember to put the piston back down to the bottom when you are done too.
May i ask why you are supposed to put piston at BDC?
So the sleeve doesn't contract on the piston and shorten the longevity of the pinch. They cool at different rates because they're different alloys.
Take the glow plug out and use something like a tooth pick to touch the piston. CAREFULLY. Then rotate it until the pistons at it's lowest point. Mark the flywheel with a paint marker for a reference point. I don't recommend anything but after run oil. A 5 dollar bottle will last you for at least a year.
