Hello,
I'm not a pro at fixing and tuning RC Nitro trucks, as a matter of fact I'm quite new to the world of Nitro RC. Lately I have been having problems with my T-Maxx 2.5 . A month ago when I turned it on it would run great for about 10 minutes. After about 10 minutes or even less you could notice a huge difference in the acceleration and top speeds. It became extremely sluggish and kept driving faster and faster without me applying the throttle! My idle speed is to the lowest. Just before, it would shut off when you give it medium throttle. This model is under a year old and has only been driven gently (1/2 a gallon fuel). I finally decided to try and return the Carburetor high-speed needle setting to factory default. In the manual it says to turn it closed and than 4 turns out from there.
This must be where I went wrong. So, I tightened the high-speed needle (I tried not to overtighten. I gently tightened it until it wouldnt go in anymore, without applying very much force at all). I had done this once before without any troubles. After this I turned it 4 full turns loose and attempted to start the engine. I noticed that the fuel was dripping to the ground and found out it was coming out of the carb under the high-speed needle. I realized that the entire needle was loose. It no longer tightened.
After this I took out the high-speed needle and noticed that the entire thread came out with it!!! (Atleast I'm pretty sure, there was brittle coil around the needle threads which came off). I've read that turning any engine screw too tight can strip but I'm sure I didnt tighten it that hard its just common sense...
Now the high-speed needle no longer sits tight and fuel spurts out, this means i need to purchase a new carburetor right?
I may sound really dumb (maybe I am) but this really seems bad :S
