t maxx 15.
makka196
united kingdom
Hi guys i have got a old t maxx with the pro .15 engine I've been doing some upgrades on it recently and just bought a Picco p2 26 engine will it work?
thanks :thumbup:
Old engine on right new on left :)
Will it fit, yes (you already have the needed mount) but you will need to swap the old pro.15 throttle linkage to the slide valve carb linkage and you will need some driveline upgrades or the Picco will tear the little pro apart.
Umm, if your still running the stock pro.15 driveline I suggest everything, including the tranny (foc is a must) and the diffs (the old style diffs can't handle the torque of the picco and you will shear the screws that mount the ring to the diff cup in short time. The center shafts and wheel shaft will also twist like a twizzler stick after a couple of hard runs.
You could run the stock driveline as is for a bit if you’re easy on it but once your finger gets heavy on the throttle the stock driveline will fail rapidly.
You may want to consider buying an extended chassis 3.3 roller and mounting the Picco on that. The longer chassis will help keep the front down somewhat and the driveline really only needs to have the rear shaft replaced to be pretty dependable.
The short chassis will be a wheelie machine unless you have a lot of throttle control.
I've found a 3.3 chassis and a extended, I can't find a roller :/ what would be best for the engine and easiest to transfer parts from my old pro .15
Check ebay,plenty of rollers there
transmited from a mobile communications device
i live in the uk an ebay does not have any in my country i dont want one from abroad as ill pay a load of taxes. thanks anyway
