Hey guys, new guy here. I just got a nitro 4-tec about 3 months ago and i noticed that the handling is very poopy. :arrr: I bought the sway bars but they don't seem to be any help. For those that have the same car, (Or any on-road sedan) can you help me with the suspension settings? How to set up the sway bars? Right now: There are 8 settings for the front and the rear. (4 up front, 4 rear) Rear, i put it on the 3rd stiffest setting, and up front, i put it to the highest/stiffest setting. Still oversteers, need help. ALso, i was wondering if it's worth it to replace the shocks with something else. (I don't race, just bash the parking lots) Any help would be great, thanks guys.
First thing take off the factory shocks, those things are junk ! I replaced mine with hpi threaded bodies shocks . I used the hpi set up and it worked fine. You can tune with diffrent shock oil and diffrent springs. Diver has perfect info on setting up your suspension , but some of the suspension is fixed. I.E rear toe-in etc. check to see if any of your arm are bent. One bent arm can cause havick. Plus are any of ur tires are worn down? If so replace . Hobby people use to have some aftermarket alum parts for the 4-tec , Just don't waste ur money on alot of parts for It like I did . If you want a good handling basher thats easy to adjust save up and by a ntc3. hope that helps !
