strange problem please help???
maximusjacko
RCTalk Rookie
hi people iv got a savage 4.6 ss the problem is the throttle trim!! when i try adjust the throttle trim on my cotroller it adjust the brake for some strange reason iv tried swapping chanels on controller but still the same all the servos are in reciver correctly and all work fine apart from this???? really messing with my mind any ideas??? thanks...jacko
yes there on the same servo but its not adjusting the carb only the brake??/
the carb and break move at the same time .. they are hooked up to the same servo ...if the break moves , the throttle should move to ...they work together .......maybe its just not moving enough for you to see it ...or your linkage might need adjustments
There's a spring on the linkage for a reason. When applying throttle, the linkage slides through the control arm on the servo. When hitting the brake, the arm pushes against the spring without pulling the throttle past idle.
Turn the trim completely down, then set your idle. After that, you can make your brake adjustments.
