stiffer shocks
No, it will adjust your ride height, you need to locate some spring stiffners that come with all Traxxas models.
They are on the bottom of that parts tree pictured, the more you add the stiffer you get lol...
You can change the springs like phins fan said, you can also replace the shock oil to a thicker oil, I like to use 60 weight shock oil.
Also, the position you put the shocks in has a big affect on what you want it to do, its the pivot point that you change when the shocks are placed going strait up and down or if they are on a angle, the stiffness will change when you change the pivot of the a arms.
http://traxxas.com/pitpass/howto/news/Complete-T-Maxx-Performance-Guide-Part-1
^^^^ this a great link, it explains how to set up your tmaxx and why or what the difference is between the adjustments.
