Just got my Savage 4.6 out to do the break in, but I did have to lean the HSN out almost an entire turn before it would even get close to 200 degrees, but still plenty of smoke.
but anyway, that isn't the problem.
After about 1 tank, I noticed my carb slider was not returning to the idle position (engine off). The carb return spring was still there, but the carb slide required a push to return to idle. Then after a couple movements of the slide with the linkage off, it started to stick worse. I put the linkage back on and the servo almost couldn't pull it open. Anyone else have this problem?
I imagine I will have to contact HPI to get a new carb. If the carb can't return to idle, there is a very good chance of a major runaway.
