steering slow to one side
mtidwell
Hey guys, new to the forum.
I do not know much about these trucks.
The revo 3.3 was in the closet for a few months. When i ran it last all was good.
I got it out and the controller would not steer, it would run the throttle but not the steering . So i got a new controller . Now the steering works, But is slow to the the right. It works great to the left like it is supposed to but slow turn and return to the right?
Battery pack is charged fully.
What do you think?
Are you running two steering servos? If so, they may be "fighting" each other. If this is the case, disconnect the linkage from both servos and then power up the TX and RX to center the servos and then power everything down. Carefully reconnect the servos and you should be okay .
If you're running 2055's, the I would suggest upgrading to the 2070 digital servos. I run 2 of those for steering and one for throttle and the response is almost instantaneous
Also check the pivot balls on the carriers and the caps. I had mine cranked down too tight and it was hard on the servos. You want them loose enough to give free steering, but tight enough to prevent slop.
