steering servo
guru350
elmont
i changed my arms 2 alum front an back but now my steering servos acting up the wheels barely move wen i turn an the servo is making a noise like a old plastic fence would make wen you open it should i buy a stronger servo?
or change a part..
make sure the servo was at nuetral when you put the new arms on and set your steering trim on your radio to zero
check batteries?
Mabye check the screws that hold your steering knuckles on. They could be too tight, causing the joint not to move freely, hence the squeaking noise. This will also stress your steering servo too much, and, if left unchecked, it will fail.:yes:
yeah +1 on what chicken leg said i would check the pvot balls and pivot ball caps
