Steering problem with my Team Associated Monster
Mytruck
I have a Team Associated GT 8.0. Had an "accident" the other day, and had to replace the upper and lower suspension arms and the shock assemblies on left side. Now, when attempting to turn, I can't seem to turn all of the way to the left. The truck will steer all the way to the right, but seems to have a hesitation and won't go all the way to the left. Any suggestions?
Check where the pillow balls go into the carriers. If not set right you won't be able to turn properly. Also check your linkage to see if it got damaged as well.
I would wonder if you skipped some teeth on the servo saver that is causing you to turn 1 way but not the other. Take the saver off, turn truck on, and reposition saver so the wheels are as straight as possible.
