Thank you for your response, and when I just start the truck and what I mean by that is right from my room, I have to prime it. With my idle needle I am taking my truck to my lhs to have them tune it. I'm getting sickintired of screwing it up every time I try to do it and I allways mess something up, its my first nitro truck.Yes my fuel is fresh rite from the one-gallon container. My air filter is clean. No I haven't tried my throtlle trim it is pointing rite at the zero what way do I turn it to increase the idle/decrease, when you say trim the throttle what do you mean. I usually run it in about 60 degree whether. When it usally gives me the most trouble starting is when I take many High speed passes and then I bring it in and it just quits I thought at one point it was to hot so I richened it and it still ran hot 170 on a 60 degree day, so I leaned it back out again thinking that it was getting to much fuel it couldn't go up far enough and it still did it. I checked the blue smoke and I still have a good amount comeing from it what do I do could I adjust any more needles, what way to you turn the idle needle to increase the idle.
HELP:surrender
