Stalling
sinesthezia
I took my Raze out to the dirt track for a bit yesterday and it was doing really well.
Then at one point I hit the brake and it stalled. I took it off the track and tried starting it up again. It would start but when I gave it throttle it would stall. Or when I hit the brake it would stall.
I tried making some adjustments to the trim, the low-speed needle(not sure if that would had anything to do with it but I gave it a shot) and the idle screw.
I really have no idea on what is going on. I was going to take it out today and try to figure it out. It's bugging me because it has never done this before.
Any suggestions??
-Em
My .12 Dynamite was doing that also and I richened up the high side screw and that fixed it. Had same problem with my Traxxas .25 and did the same and it worked also. Give that a try. You also might have got dirt into the carb. Try to blow it out with compressed air.
Are you checking the engine temps regularly? That's the way to keep track of its' proper tune. Outside temperature and humidity also require a bit of tweaking since it effects the performance.
