Need help on t-maxx 3.3 spur gear adjustment
Had to replace my spur gear and need help
Got the one with the two washers need to know how tight the nut
Is suppose to be
thats good to do if you have a spring ...he said it has 2 washers ...so randall is right ..tight it so you can barely turn the spur with your hands ...and this method is good for both setups ...
he has the setup with 2 washers ....tightening it all the way down can ruin the washers ..if the washer get flatten to much , they wont do what they are supposed to do ...
the way you do it is good if you have the spring instead of the washers
