spur gear
inkslingrrr
hey folks just a quick question, but i dont have alot of details, here goes: i was fixing my sons savage 21... he said it just quit moving, well i found that the nut and spring on the front of the spur gear had gotten so hot it actually melted the center out... any ideas why??? i asked if he got it stuck and just rooted the hell outta it and he says no, it was quite muddy out. all i can think out was duration of play, just hopin it isnt mechanical...any ideas or insight would be great!!!
Exactly what Snook said. You were too loose and it melted.... Tighten down and back off about a 1/4 turn. I would not smoke it down all the way for bashing. It needs to slip if it gets bound up a little so nothing breaks. Spur gears are cheaper than diffs. You can also make sure the fiber lock portion of the nut is still holding too. If it is worn out it can back off easier.
If it still slips, you need to take the gear off and look at the back of it to see if you smoked the fiber clutch pad on the back of the gear..
