pontiac69
I reciently stripped the plastic 70 tooth spur gear. I went bought a new gear only. I reused every thing else. Was i supposed to replace everything. I even used the stock plastic pins that go in the gear. Well i used it today and it just spins. It looks like i didnt have the nut tight enough and it started melting the gear where the clutch was slipping. So i am going to replace everything. Even with it as tight as i can make it, it doesn't move it jus slips. My question is am i supposed to have the nut tight. I had it tight but i guess not tight enough since it was just slipping. How tight should that nut be...
