wannarunem
What happened here????
This is my first encounter of this problem. I was running in high grass a little awhile ago when this crap happens. My gear mesh was good. Maybe it got to hot. I'm not sure if it was melted or chewed up....was the nut to tight that holds the spur gear? If it was to tight why didnt the outer teeth strip out?..or does an over thightened nut cause damage to the inside of the spur like this? I've never tackled this problem before..kinda lost here...I've only seen stripped teeth.
I tried to tighten the nut afterwards and it just spun..never got tight.
Is the gear reusable if i change out the pad? I have one more of those but no more gears.
P.s.!! The blue and gold that u see through the hole is only a sticker.
