On the big gear on the transmission is held in place with a spring and the nut. In between the gear and the transmission there should be a plate and some sort of pads (the slipper). The spring is there to set the pressure between the rear and the slipper. More pressure is applied the to slipper when the nut is tightened making it slip less. The purpose of the slipper is to adsorb the shock to the drive shafts, transmission, diffs, and gears of the power train after a rapid change in well speed during jump, donuts, burn outs and hard launches.[/
I just figured it out, it was my engine mount again because I'm missing two screws from on side and one from the bottom. So my not using lock-tight is making my car throw screws probably due to the vibration of the engine itself.
