Wolfgang10
I was warming my car up today before i tried messing with the LSN and the HSN. Everything was cool and then I noticed I could whip the rear end around really easily and do dougnuts like nothing. I knew my driveshaft was not working properly and then "clink, clank, clank" it fell outta the side. No big deal. Picked it up and even found the collar to it too!
Now here is where it gets crazy.
I turned it off by covering the air filter as soon as the shaft fell out of the car completely. I was trying to get it started again and it would start, rev real high, then die. So i feathered the throttle and got it to start, but it would rev like crazy and kept trying to drive off my table!
Then i tried to start it again and heard the strangest noise. It sounded like a "pink" and then i saw the flywheel spinning freely as if not connected to the engine at all! I was able to turn the flywheel freely without any resistance. I tried the pull start again and then it was back to normal, like it popped back into place. I pull again and the flywheel spun without turning the motor over. I then gave up and ran straight to my computer knowing you guys could help me.
WHAT HAPPENED!??!?!
WHAT HAPPENED!??!?!
