RustyBoltz07
Ok, I got my act together over spring break and have really been getting deep into things for my Revo and Sirio.23 so I have some questions that I was hoping might be cleared up. :shrug:
1. How hot should my Sirio .23 be getting? I use a McCoy #9 plug and currently it runs in the range of 260-300 with by MIP saying peaks at 320
A. Are there any alternative plugs including options for turbo?
B. If too hot, should I reduce the compression, or consider a large head?
2. I've been using stock gearing and I mostly bash, should I consider a gearing change? if so what suggestions?
3. How do I check to see if the slipper clutch is correct?
4. My Revo takes a lot of trigger pull before it begins to move(stock), should I
A. consider racing clutch like the new Werks clutch http://werksracing.com/product.do?sku=WRX6501 or
B. Consider adding weight to the shoes and how or
C. get heavier clutch shoe
or do you have any other suggestions?
And soes anyone know the peak rpm for the Sirio .23, I read it in Rc Nitro but have long forgotten.
thanks for any help concerning any of the questions.
