I got a problem slover for all of you guys that cry about the receiver box on the savage. Well guess what I got a solution to that problem. first you will need a 1000mah hump pack. Second youll need a swith that has 3 ends. Third get a hump pack charger. Take and unsrew the screws in the old swith. then take the swith out and screw the other one in. then take the hump pack and put it where the old batteries set before. Then if you place your savage in the center and take the wire that is coming out of the left side and connet it to the hump pack. Then find out which one you charge with and then after you did that . then take the top and put it back on, and leave the wire for the charger outside of the box. then take a tie strap and put it around the roll bar and take the wire an make a loop and put that loop in the zip tie. No more problems.
