matturnerr
I just got this smt10 today and was driving it around the yard then I lost steering completely took it inside to check it out and the gear and part of the horn was still moving as should when you turned the wheel so it responded fine and I knew the servo itself is working so I figured the horn was stripped but when I took it off it seemed fine to me on both end and even went back on like a charm it just makes no sense to me I’ve checked all my links to see if anything is lose or what not when I inspected the horn it looked as if something hit it you could tell a tiny piece of plastic came off on the edge so then I figured okay let’s try this other one that came with at as a replacement I put it on and no luck any help appreciated thanks
